Rear Wiper Blade for Hummer H3
Old Aug 9, 2012 | 05:47 PM
rmach3's Avatar
Default Rear Wiper Blade for Hummer H3
Anyone have any suggestions for a good durable rear wiper blade for H3?
I looked at RainX but they advised that they do not have a blade to fit the H3.
Thanks!
Old Aug 9, 2012 | 06:17 PM
I installed an Anco Aerovantage Blade (part # 91-12)... Works great, no problems so far, and cheap (Around $5-Bucks oop$ )
Old Aug 9, 2012 | 07:11 PM
rsc's Avatar
rsc
IIRC, the H3 uses a 12" blade but a 13" blade fits and as a bonus also wipes more surface area. Another thing to do when back there would be to re-clock the arm a spline or two to allow it to sweep farther over instead of stopping almost straight up.
Old Aug 9, 2012 | 09:05 PM
RKSmith163's Avatar
I also used a 13 inch. There is a larger selection of those and they go all the way to edge of the window at the top.
Old Aug 9, 2012 | 09:06 PM
rmach3's Avatar
rsc, thanks for your input. Can you give me more feedback on reclockign the arm.
Thanks,
rmach3
Old Aug 10, 2012 | 12:15 AM
rsc's Avatar
rsc
Depending on you, your tools and your spare size- remove spare from rear door.
Lift up hinged cover at the central pivot point for the wiper and access the nut.
Loosen or remove nut.
Lift wiper arm off splined shaft and rotate counter-clockwise one or two splines as desired.
Your swept area will stay the same, but the area cleared will now be more centered in the rear window. On mine, the wiper parks at about 2 o'clock vs. pointing nearly horizontal stock.
Old Aug 10, 2012 | 09:05 AM
rmach3's Avatar
Smile
Thanks for that!
Old Aug 10, 2012 | 02:28 PM
That's not what she said.................... bada boom!
Sorry, it's Friday and I could not resist.
Old Aug 10, 2012 | 02:44 PM
RKSmith163's Avatar
Smile
She said gime me 12 inches and make it hurt...so we did it 4 times and then I hit her in the head with a brick......
h3andme
Mar 21, 2022 10:51 AM
BusterBrownH1
Apr 27, 2014 09:56 AM
jeff618
Mar 22, 2011 04:00 PM
Navadisha
Mar 11, 2011 11:53 AM
IgottaH3
Oct 22, 2007 07:19 PM
