Radio volume problem
This is my first post and I already have some questions.....I purchased a used 2006 H3 I love the car. However, I noticed that when I'm driving and stop (red light, stop sign etc.) the volume of my radio goes down, but when I take off again the volume goes back up. The volume change is very slight, but noticable. Any ideas?
By the way GREAT SITE! |
RE: Radio volume problem
On your radio at the bottum right there are two small buttons , Auto EQ and Auto Vol , if my memory is right . The one on the right auto Vol - push it and the radio will read - min vol , max vol , off . Set as desired, it is for the volume on the radio to go up as you speed up .
Your memory serves you right.
ORIGINAL: xchief On your radio at the bottum right there are two small buttons , Auto EQ and Auto Vol , if my memory is right . The one on the right auto Vol - push it and the radio will read - min vol , max vol , off . Set as desired, it is for the volume on the radio to go up as you speed up . |
I think it has to do with falty wires maybe your alternater isnt goin and make sure you dont have corrosion around your battery terminal or check the spark plugs .
SCV - speed controled volume, GM has been using at least 10 years now. It can be set to off or a number of settings.
ORIGINAL: Fireman SCV - speed controled volume, GM has been using at least 10 years now. It can be set to off or a number of settings. |
The settings suggested on the radio worked thanks!
