radiator
Old Jul 30, 2006 | 04:12 PM
bigwood212's Avatar
Default radiator
hey! did you know the back radiator shroud comes off in like 2 seconds. Theres a **** that you bring around from the leftside and it opens up the bottum so you can slide it out threw the fan. Theres only 2 clips you push in with your thumb on each side after that. Then you pull it up. I just disoverd this while trying to get the mud out the back side of the radiator. makes it a lot easyier to clean. I've seen h2's fold down their whole front grill though. they shouldve dont that here.
Old Apr 24, 2007 | 03:13 AM
anthony42376's Avatar
Default RE: radiator
This was awesome information! I got into a mud pit this past weekend and the following day my H3 started running really HOT! But not to the point of boiling over. After reading your post on how to remove the radiator shield I was able to flush out all the Red Clay Mud that was clogging the fins. After a good spraying I watched all the MUD come out of the fin area and she is back to normal. Your information saved my trip this weekend. I m planning on going to Windrock this weekend in TN. And I was about to cancel because of this issue. But all is saved now! Thanks :-)
Old Jun 9, 2007 | 02:16 AM
sean's Avatar
I already know that information when a friend of mine told me about a **** of his back Mazda radiator shroud that his mechanic for easy removal of his radiator.... I guess most of car owners know that...
Old May 29, 2008 | 06:02 AM
Gunner_45's Avatar
This would be useful info IF I could find the damn **** they are talking about ! ! !
Must be getting blind in my old age.......
Old Jun 15, 2008 | 09:01 AM
josh1899's Avatar
I couldn't find the **** either. I just removed the 6 nuts, and took off the grill to clean the radiator. Pretty easy.
Old Oct 2, 2012 | 03:38 PM
jhebbert0306's Avatar
how do i remove the radiator all together
Old Oct 2, 2012 | 03:46 PM
https://www.hummerforums.com/forum/h...bumping-23221/
PLEASE search first, then if you can't find your answer, then a new thread that asks for the instructions for radiator removal.
Old Oct 2, 2012 | 11:12 PM
Are you going to "air cool" the motor of your HUMMER like an older Harley?
I'd use a huge box fan from Wal-Mart and an inverter.
Old Oct 3, 2012 | 12:21 AM
rsc's Avatar
rsc
He must be going to a total loss water/ice system. I'm guessing it's a tray with a mesh bottom mounted over the engine to take advantage of the direct engine block cooling effect of the dripping water.
Old Oct 3, 2012 | 07:03 AM
wfturner's Avatar
Is it me or is Doc getting really good at Photoshop ??
john_85
Jun 5, 2008 11:21 PM
magnumoffroad
Jan 22, 2008 04:53 PM
hummerhonduras
Nov 11, 2007 04:53 PM
tomp
Sep 30, 2007 09:16 AM
gangstagirl
May 5, 2007 06:14 AM
