Question on '06 - '07 H3's...
Old Nov 26, 2007 | 10:17 PM
VanSmite's Avatar
Default Question on '06 - '07 H3's...
Since my quest for a Hummer, I have had my father and sister now interested in an H3. Sister could afford an 06 possibly an 07. So what are the biggest differences between an 06 and 07 H3? Shouldshe consider 07's only?
Old Nov 26, 2007 | 10:25 PM
mh307's Avatar
Default RE: Question on '06 - '07 H3's...
The 07's are slightly revised basically. The engine was increased from 3.5 liters to 3.7 (a/b 20 extra horses). The 07's have the window switches further up on the door i believe (my 07 has fine switches, but i've heard complaints on the 06s) and i think the 07's have headlights as Daytime running lights as opposed to the parking lights on 06's. That's allthe differences i can think of...i'd love mine (07 H3 adventure) but i can't say on the 6s.
Old Nov 27, 2007 | 04:44 AM
hilljob26's Avatar
thats pretty much it,the window switches are probably the biggest improvement,as the ones in my 06 are kinda far back on the door to me
Old Nov 27, 2007 | 08:34 AM
alrock's Avatar
The window switch move was halfway through the 07 year - my early 07 has the switches far back too. The engine is the biggest difference. [/align]
Old Nov 27, 2007 | 10:03 AM
The 07 3.7L "offers a substantial 22-horsepower increase and 17 lb.-ft. more torque than the previous five-cylinder" 3.5L engine. According to a GM press release.
Old Nov 27, 2007 | 07:40 PM
VanSmite's Avatar
Thanks gang. Anything else? I noticed the 06 came in blue and a green that was nice.
Old Nov 27, 2007 | 10:50 PM
azz7772's Avatar
in my opinion the switches are not a big deal i love my 06 hummer it has 62000 km now and very few troubles, i had the cracked roof rails, a heater core ,the horn ,and just recently a slow leak in a seal on the transfer case which will be warranty and thats it.
Old Nov 28, 2007 | 06:29 AM
TheGunnyRet's Avatar
For interior changes it was done on the 2007 1/2 rear models, Moved the buttons forward on the left door, supposedly the Brake and Gas pedal had been moved more slightly apart, Don't know about the DTRL.
Engine Changes:
2007 Vortec 3.7L I5 VVT (LLR)
2007 model year summary
• Increased displacement and power output
• Larger intake valves
• Larger exhaust valves
• Valve lift and duration optimized
• Cylinder head intake and exhaust flow increase
• Larger close-coupled catalytic converter
• Increased PCM memory for new diagnostic requirements
• Meets new BIN 5 emission requirements
• Aluminum cam cover for reduced noise
• Sophisticated noise-reducing oiling system
• Tighter clearance balance shaft bushings
• A.I.R. system added to reduce emissions
• New cartridge block heater
FULL DESCRIPTIONS OF NEW OR CHANGED FEATURES
INCREASED DISPLACEMENT AND POWER OUTPUT
To increase displacement from 3.5 liters to 3.7 liters, the bore was enlarged from 93.0 mm to 95.5 mm. The increased displacement contributes to an increase in both horsepower and torque (see specifications). The compression ratio remains an efficiently high 10.0:1.
LARGER INTAKE VALVES
To optimize the greater volume of intake charge allowed by the increased displacement, the intake valves for each cylinder have been increased in diameter from 37 mm to 38.7 mm.
LARGER EXHAUST VALVES
To allow better flow of exhaust, the exhaust valves have been enlarged from 30.5 mm to 33.5 mm.
VALVE LIFT AND DURATION OPTIMIZED
Camshaft lobe profiles have been changed to optimize the lift and open/closed duration of the larger intake and exhaust valves for best efficiency and performance.
Old Nov 28, 2007 | 06:42 AM
HUMMER DRIVER's Avatar
WARRANTY!!! THE 2007 HAS GM 5YR/100K Mile Warranty 2006 doesn't....
Old Nov 28, 2007 | 09:01 AM
rhill20's Avatar
The biggest differences I have noticed between our 06 we had and my 07 are the window switches, the 3.7 motor, and warranty. Can't say that I have noticed anything else. The only difference I have notice between the 07 and 08 are that the mid front grill has anX designon the 08 andO designon the 07.
