NO chip in an H3 key.
If you need a copy you can get them cheap from anywhere that does automotive keys. DO NOT get copies made at a dealer. |
Originally Posted by Bunger
(Post 318866)
If you need a copy you can get them cheap from anywhere that does automotive keys. DO NOT get copies made at a dealer. why American cars are too underdeveloped ?! no chip, stereo has no code( mostly I assume not exactly sure about h3, and no connection to pcm I assume ,so it's isn't linked to one car I may be wrong) upto 2010 and anyone can hijack the car in 1min ? just have to get over the steering lock and drive away? so awful sorry man, just expressing my anger of course I won't get a copy made at dealer for a piece of metal !!!! :D thanks for your replay |
I may be wrong yes u may |
OEM radios ARE linked to the vehicle. If you installed another OEM radio you would need to have a dealer reprogram it to be accepted.
You can install an aftermarket radio with no programming needed. |
Originally Posted by a7m1
(Post 318867)
I may be wrong
(Post 318869)
yes u may
sorry |
(Post 318881)
You can install an aftermarket radio with no programming needed. it has somehow linked to ecu via vin number or something else, i just wasn't sure it its implemented or no! so if u managed to install it on another h3 would it ask for code? or it will need some special programming to make it work to new vin? apologize i have no user manual nor code i bought the car used if for example someone managed to steal my stereo and install it in ajother h3 but didnt mess with it and i retrived it!will it work instantly or remain locked?? does it have sort of cmos battery and stores information in ram or rom? for example if i left h3 for 10yrs without battery will radio work wheni put battery back i guess my questions make sence thanks |
H2 won't start after trying to sync up to remotes
Originally Posted by Garyarm1951
(Post 344418)
1) This is an OLD Thread last posted in 2.5 years ago.... https://www.hummerforums.com/forum/n...bumping-23220/ 2) You are asking an H2 question in the H3 section. Do a search. |
I programmed my keyless remote on my 2007 h2 and now car won't turn over, not even a l. Click when I turn the key, any ideas out there?
