Programing keyless entry?
Old Jan 18, 2011 | 06:28 PM
ctdrl-1's Avatar
Default Programing keyless entry?
Anyone out there know the procedure for programming a new keyless entry remote for a 1998 H1?
Thanks,
Brent
Old Jan 27, 2011 | 10:39 PM
OldYelr's Avatar
This should work for your '98 but I make no guarantees. Mine is an '03 and has a button instead of a wire but the process is similar. Your mileage may vary, so use at your own risk.
The receiver can be programmed to work with up to four transmitters. To add, replace and/or delete transmitter:
1. Locate the unconnected gray wire with a pink or red connector taped to the remote entry harness connected to the receiver module beneath the console cover.
2. Assemble all the transmitters to be used.
3. Turn on the ignition switch.
4. Ground the pink-red connector four times in succession. The parking lamps will flash four times and the system will reset itself in the program mode.
5. Push the button on any transmitter and the lights will flash once.
6. Repeat this for the remaining transmitters for up to four transmitters. The above must be accomplished within 30 seconds from grounding the gray wire connector or the system will exit the programming mode and the procedure will have to be repeated.
7. Turn the ignition switch off following the above and check each transmitter for correct function.
Old Aug 2, 2015 | 12:15 PM
ArgentinaHummer's Avatar
Thanks,
Brent
Dear Brent,
I have got the same problem to programing a new remote transmitter for my H1 (1999). The advice of Old Yerl does it work? Any tips to give me?
Thanks , Billy
Old Aug 14, 2015 | 11:52 AM
V-tek's Avatar
My 99 has a Clifford Arrow in it and these instructions worked for me.
http://www.directeddealers.com/manua..._11-06post.pdf
Old Aug 20, 2015 | 03:20 PM
Hy , I found the solution for my H1.
Programming Keyless Entry Remote Transmitters.
It s works !!! Very simple
E T H
May 3, 2018 10:04 PM
bham57
Jul 6, 2009 01:20 PM
H2Germany
Sep 8, 2007 11:09 AM
khoolhandz
Dec 15, 2006 11:30 PM
93Miata
Oct 8, 2005 11:50 PM
