Power Switch ?
On my new PIAA's, it came with a digital switch with 2 buttons that goes to a relay for each lamp..one button for on/off and one button for spot/flood.
I would like to consolidate this digital switch to a single analog switch that works in a on/off/on mode. I have a switch designed to do this.. ---12v+ input ---12v+output ---12v+ input Anybody know if it will work like this??... ---12v+ output 1 ---12v+ input ---12v+ output 2 |
RE: Power Switch ?
it should work that way, center pole is making no contaact when in center so you are fine there, will make contact with pole 1 when in the up position and contact with pole 2 when in the down position,but instead of getting power from pole 1 or 2 and sending it to the center pole it will be getting power from center and sending it to pole 1 and 2 (up&down)
yea should work ok. |
| All times are GMT -5. The time now is 03:43 AM. |
