Power Steer Critical Failure
Im experiencing a rather leathal problem with Hummer H2 2009.
While driving on the buissy highway doing around 120km the power steering suddenly failed. No chanse of turning the steering wheel at all. All I could do was to slam the breaks and hope for the best. I felt like a sitting duck! Lucky other cars were able to avoid me, pure luck! The engine was running and all other systems but the steering was operational. Turning off and then on again restored the steering function. Needless to say a brought the car to the GM dealer and said - wtf! Two days later they returned the car and said - there is nothing wrong Sir. Well, today it happened again when my wife and 4 year old child was using the car. I need urgent assistance resolving the issue. As a matter of fact I think GM should tech out and explain what the hell is going on here! |
Replace power steering fluid and/or pump and belt. Also, check for leaks in all hoses.
Originally Posted by OWRLTD
(Post 339070)
I hope this will fix the problem but also restore the confidence lost! |
Even if you loose your power steering, you still should be able to turn the steering wheel albeit with extra force.
Is 2009 still hydraulic steering or did they go to electronic steering? |
(Post 339072)
omg...glad u and ur family are ok. hope u get it fix asap.
Any chance this could be an ignition problem? like the steering wheel locked up because of the ignition lock? You should still be able to steer easily at highway speeds without the power steering.
Originally Posted by H2CANEPADESIGN
(Post 339235)
