Oxygen Sensor code
Old May 14, 2012 | 11:45 AM
JAYG0351's Avatar
Default Oxygen Sensor code
I got a check engine light last week and Onstar says its related to an Oxygen Sensor problem. I did some searching here and found out it could be fuel injectors needed cleaning. I bought a bottle of gumout and put in durnig a recent refuel. After driving down the road a few miles the light went out. Now it has conme back on this morning and Onstar reports same code. Could it be a loose wire on the sensor or could it need a replacement. I Have a 2006 H3 with 80,000 miles. If it is the sensor are they hard to replace, and where are they located.
Old May 14, 2012 | 02:02 PM
2wheelmonster's Avatar
The oxygen sensors are not difficult to replace. If you live near a AutoZone or Advanced Auto they will hook the computer up to it and tell which sensor it is exactly. There may be other parts store that may offer the same service for free as well.
Old May 14, 2012 | 02:31 PM
A check engine light and a code are two different things. When asking these questions, can't really help you unless you post the code itself.
Two sensors, both in the exhaust manifold. The code would tell you which one is not operation correctly. When O2 sensors get old and dirty sometimes they do not work fast enough, hence the light can come on and go off based upon a intermittent problem over several ignition cycles.
Don't waste your $$ on fuel additives, just always use top tier gasoline.
Old May 14, 2012 | 03:10 PM
drtom's Avatar
Banned
member for2 yr + huh,youve been lucky not needing to post anything in all that time. hmmm
keep coming back,,
Old May 23, 2012 | 10:57 PM
thedave8's Avatar
keep coming back,,
a
r
s
h
o
l
e
Denise ward
Jan 20, 2015 08:21 PM
C31322
Sep 11, 2013 03:27 PM
New York City
Apr 29, 2013 12:11 AM
Kimmea
Aug 1, 2012 07:47 PM
mtauseefsa
Jun 19, 2012 09:05 AM
