Oil cooler lines
Old Jan 21, 2018 | 07:57 AM
drewandsteph's Avatar
Default Oil cooler lines
Hi guys. My 03 h2 had some oil drips under the drivers side front almost under the headlight area. After popping the hood and checking it out I see that the two lines going into the radiator drivers side top...appear to be the culprit. Do I change the fittings or the whole line. Looking for any help and encouragement. Thanks
Old Jan 21, 2018 | 09:44 AM
tharber's Avatar
Oil cooler does not go into the radiator. its a separate cooler in front of the radiator. In any event, have you tried to tighten the fittings yet?
Tim
Old Jan 21, 2018 | 11:45 AM
LoJac963's Avatar
I am fairly certain the oil cooler is integrated in the radiator on the driver side and the tranny on the passenger side of the radiator. The external radiators, the small one is a power steering cooler and the one in the middle is the tranny cooler.
Old Jan 22, 2018 | 07:45 AM
calif phil's Avatar
LoJac is correct. The oil cooler is in the radiator. I suppose it could be the 0 ring inside the fitting. I would replace the lines with GM parts if you suspect the lines have a leak. You do not want to have one blow while driving. Since I don't use my H2 for towing anymore, if my lines went bad, I think I would remove and bypass them.
Old Jan 22, 2018 | 07:50 AM
I watched it forever last night till I finally saw it drip. It's coming out around the line right at the fitting. Can the fitting be replaced or do I need to replace the whole line. How hard is it to bypass?
FatJay
Jul 30, 2021 11:28 AM
heyttsguy
Jul 16, 2016 02:29 PM
ODIMUS
Apr 22, 2015 11:38 AM
ghawthorn
Feb 20, 2013 09:10 PM
angiebell71
Sep 14, 2012 12:51 AM
