No powersteering or brakes
I'm new to this, have never posted on one of these before. I have a 03 hummer h2. I'll admit I was fooling around in the snow and did a donut, and lost my powersteering and brakes.. I was curious if anyone has ever run into this problem and knows how to fix it? Any information would be helpful! Thank you
Welcome to HF.
I MOVED this thread from the H3 section because......... get this......... H2 questions go in the H2 section. Now maybe somebody can help you out. |
Check the drive belt for the power steering pump.......... Some GM veh's use the PS pump for the brakes also.....
Hydro-boost power assist was introduced in 1973 by Bendix as an alternative to the vacuum booster. The hydro-boost uses the hydraulic pressure from the power steering system to provide the driver assist in applying the brakes. In short, repair or replace the Hydro-boost. It is located behind the master cylinder, takes about an hour.
Originally Posted by H2 Chief
(Post 341231)
Hydro-boost power assist was introduced in 1973 by Bendix as an alternative to the vacuum booster. The hydro-boost uses the hydraulic pressure from the power steering system to provide the driver assist in applying the brakes...
