New Air Horn
Screw train horns, they are expensive, big and take tons of air. I just installed a fire truck horn and it is the BEST!
I highly suggest you get one. It fits perfect between the T-Bar and frame rail. Completely out of sight and SO LOUD!!!!!!! http://www.airhornsoftexas.com/emergency/emergency.html Definately the kind of juice the H3 was missing! :D ..in sort of a act now, ask later... anybody know if there are laws on how loud your horn can be? |
RE: New Air Horn
ya!
you beat me to it,i was thinking of getting one also. which is louder the trian or firetruck horn? i am kinda leaning towards the trian.. |
RE: New Air Horn
I think they are pretty close. If I remember, they are rated the same decibels but who knows how they got those numbers. The plastic ones at Pep Boys say 152db but no trains are supposed to have louder than a 110db horn anymore.
The fire truck horn hurts your ears and shakes the ground. Plus its a little different as train horns are getting more popular. Want to go big? Jump to ferry horns! http://www.youtube.com/watch?v=TiWNw...eature=related http://www.youtube.com/watch?v=rjR5K_Fb6r4 |
RE: New Air Horn
where did you put the air tank,horn,and pump?
RE: New Air Horn
GR: Your link in the thread starter does not work. [:o]
[sm=ttiwwp.gif] |
RE: New Air Horn
DOH!
Looks like they got a swanky new website...here is the updated link! http://www.airhornsoftexas.com/Emregency_Air_Horns.html The air tank is in the back cargo area, the pump is attached to the fuse panel, and the horn is tucked up nicely against the frame rail under the truck right around where the T-Bar key is. Its a perfect fit...meant to be. |
RE: New Air Horn
Can you see your onboard air pressure guage take a dip when you hit the firetruck horn? :D
RE: New Air Horn
Just barely...maybe like 3-5 psi per HONK!
I could probably have a good minute long honk on a full tank with the compressor running. Usually 10-15 honks before the pressure switch kicks on to recharge. My compressor blows about 1psi per second..so it recharges to 145psi in about 35 seconds. |
RE: New Air Horn
So do you have pics of this setup on your truck?
| All times are GMT -5. The time now is 10:34 AM. |
