need wiring help 2007 H3
Old Dec 17, 2012 | 02:20 PM
lostsoul77's Avatar
Question need wiring help 2007 H3
I installed the Recon Big Rig Amber running lights w/ white courtesy lights about 3mos ago. Got everything working fine with the exception of the white courtesy lights (supposed to go from amber to white when the doors open). I tapped into the front floor lamps which results in the running lights staying lit white when the doors are shut and truck is off. Upon looking at a diagram for a 2006 H3, I see that these lights are always hot and use the BCM (body control module) to break ground. I spoke with Recon and a few friends and they suggested a 5 Pole relay to get things working properly but it would seem that the relay would always be activated and eventually burn out due to the circuit always being hot.
what i currently have right now is a wire pulled into the cab on the front passenger and driver side which need to connect up to a positive source which turns on and off when the doors open; the entire light bar is already grounded to chassis. Any suggestions?
Old Apr 24, 2013 | 03:45 PM
lostsoul77's Avatar
Anyone have any suggestions?
crank
24
Oct 17, 2013 05:21 AM
meanh1
Oct 25, 2012 07:36 AM
jshabouk
Oct 7, 2010 05:13 PM
gerry
Jan 6, 2010 03:13 AM
raptor0690
Sep 19, 2009 11:27 AM
