Need Help new Hummer Owner
Im having the code TRACTION FAILED SERVICE STAB SYS SERV 4WD someone have an idea how to clear this or if is any possible cause? Thank you.
Welcome to HF.
I MOVED your thread question because as it states in the New Member Section: Do NOT post tech questions here. You should try out the search feature here. When you post a question, it would be helpful to indicate Model, Year, Miles. There are many possible causes for the message you have, might be relevant to indicate when it started... you can't just "clear it". Could be a bad T Case encoder, wiring to it, connector, or bas ABS wheel sensor, wiring to that, or its connector.... on and on. |
What is the specific code it's throwing?
| All times are GMT -5. The time now is 08:11 AM. |
