The thread I believe was in the H3 section as those guys were going nuts over them. Those that had installed them loved the lights.
As far as a cutoff line, you won't get one in halogen housings, those are only in projector housings. |
which one are you guys ordering from here? Headlights
What do you recommend for the fog lights? Also, is it possible to adjust our headlights so they angle down more? Since lifting it a few inches with keys and UCA kit I'd like to get them adjusted correctly. 2004 H2 SUV |
I don't know what the hell is wrong with the reflectors in these things but this is the first vehicle where the reflectors have burned away. First my DRL's were completely burned off and now my headlights are starting to burn away at the top....
So now I need to look into both reflector housings and an alternative to HID's since these cheap reflectors can't take the heat. STARR's are too damn expensive and so is the truck light headlights. Maybe these LED bulbs everyone is going crazy about? Has anyone actually put them in a 2 yet? |
IPCW Hummer 03-07 H2 Head Lps Crystal Diamond-Cut W/Tri-bar only, 7" Conversion
this is the headlamp housing that I used. 6000K HID Kit [6000K] - $79.99 this is the lamp kit itself that I used. This is the drl conversion to an off-road lamp that I used. it is so incredibly bright that I cant use it on the street. |
Originally Posted by H2CANEPADESIGN
(Post 311354)
this is the headlamp housing that I used. 6000K HID Kit [6000K] - $79.99 this is the lamp kit itself that I used. Amazon.com: Delta 01-9029-HID2 Fascia HID Driving Light Kit for Hummer H2/H3: Automotive This is the drl conversion to an off-road lamp that I used. it is so incredibly bright that I cant use it on the street. |
