My H3 front Diff build, Iron, Elocker, custom Girdle
Old Sep 9, 2013 | 08:23 AM
R-code17815's Avatar
Default My H3 front Diff build, Iron, Elocker, custom Girdle
Like it says, I'm building a new front diff for my 08.
I'm switching to a Cast Iron case, Front Elocker, and making a custom girdle cover for it.
Here's my build.
Most of my parts are finally showing up. I'll update as I make progress....
New Pinion depth tool, old one sucked.
New Elocker
Cast Iron front case 2010 Alpha
Yukon Master Rebuild kit
Yukon 4.56 gears
Arp ring & pinion bolts
Amsoil SEVER GEAR (it comes in several weights, I chose this do to my heavy foot)
Old Sep 9, 2013 | 09:18 AM
The Girdle cover
Old Sep 9, 2013 | 09:20 AM
Custom SOLID ALUM diff mounts
Old Sep 9, 2013 | 09:24 AM
Random Build pics
Old Sep 9, 2013 | 09:26 AM
I'm waiting on a $6 breather tube, then it's time to install!!!!
Old Sep 9, 2013 | 04:04 PM
happythree's Avatar
Default adjustments?
looks so nice and clean,now!. I never built a diff but ive read a lot about how fussy the spacing is of the ring and pinion and also the pinion bearing preload.
did they give you a procedure to set it up or is this something you do regularly? from what I read,it seems like a tedious process.
ive swapped out ford 9 inch units to get a "locker"in a previous car. very heavy!
Old Sep 9, 2013 | 05:10 PM
I've been building diff'd for a few years now...
Old Sep 9, 2013 | 07:10 PM
SolidJJ's Avatar
Glad to see that you posted your diff build on this forum!!! That diif cover is F^%& mean *** hell, great damn job on it man!!! What in the world are those sliver metals in your new diff mount? If you don't mind me asking, how much was the cost for diff and all the new guts? I'm hoping to get an Alpha diff and I'm going to have to trade out the gears for 4:56 and mind as well put in a locker.
Old Sep 9, 2013 | 07:18 PM
SolidJJ's Avatar
One more thing, I'm not to sure on how much you know about the colorado's front diff tube works but they have a actuator that locks the front axle when they go into 4x4. How much work would you think it would take to get their actuator to turn on when we want to run in AWD?
Old Sep 10, 2013 | 08:43 AM
Just under $1,500.00
all new parts. Nalley GMC
Diff bushings are solid aluminum (personal experiment)
