mirror
Does any one know what is or how the glass is being held inmirror head cause I just got back from dealer having the whole mirror assembly replaced and it still shakes @ speeds from 60 on to 70 today I'm taking it back today to have them check it out again.the problem is in how the mirror is mounted to motor for remote ive notice it has play .
RE: mirror
It has 4 clips on the back. The mirror pops off but it's very easy to brake the mirror glass when you remove it.
RE: mirror
When looking in the mirror, push the bottom of the glass into the housing. Thenput a thin rag on the end of a pry bar and put it in at the bottom of the glass. Then carefully pry up wards on the glass and work the glass up out of the retainers. It should slide right out. To install it back. Slide it into the retainers and with your fingers push it into place.
There is a thread on this forum about a mirror with a lit arrow in it. The directions for that show you how to do this. |
RE: mirror
hello hummer mike is there a way to tighten this mirror or something after it is off ? or anything to stop the vibration shaking.
RE: mirror
what kind of tires do you run the real aggresive ones will shake everything alot more than normal
RE: mirror
My mirror shakes with the stock 33's...the whole top half of the unit from the hinge up is loose on mine, I don't see any way to tighten it either. Sounds like most people with this problem are just getting them replaced.
RE: mirror
Hey mfish,
It's a known issue at Hummer. There is an up-dated one that should take care of the problem. I just had minereplaced last week. I thought there would be a way to tighten it up also...No such luck.... Changing it out is the only way.... |
RE: mirror
Thank god I haven't encountered a mirror problem yet.
RE: mirror
thursday the 27th 0430 hrs here at work and today I will be going to the dealer for the 3rd time to put another mirror dealer is aware there is a problem two techs say mirror is just to loose and is a defect so will see 3rd mirror should be the charm ALSO told them if it was the tires that would cause shaking dealer said no cause I do have the off road package dealer again said no and they also insist that the problem is the mirror.
