For the love of god....
Old Apr 9, 2013 | 05:38 PM
youngone's Avatar
Default For the love of god....
Will someone please tell me how to bleed the cooling system in a 2006 Hummer h3 before I light this bastard on fire!?
I replaced the old T-stat with an Autozone ac delco unit and now this things gets HOT! It climbs to the 3/4 mark on the gauge.
I tried berping it by taking the radiator cap off, starting the car a letting it run...buuutttt, apparently this Hummer wants to be difficult.
Its driving me nuts, i dont see a coolant bleed port like on my 4.7 jeep, so I'm lost.
Old Apr 9, 2013 | 05:59 PM
happythree's Avatar
Default GOD loves you
the service manual troubleshooting for hot engine does not mention bleeding anywhere.
you might need to pull the tstat and test it. also verify its not backwards.
they say,"SLOWLY add coolant",???
fill coolant reservoir,replace caps,run till warm, let it cool, top off reservoir.
Old Apr 9, 2013 | 06:12 PM
youngone's Avatar
I bought the thermostat that comes in the housing and I;m pretty sure I have it installed correctly. The rib is facing up.
I'm gonna be really angry if it's bad, it isnt the easiest part in the world to change.
Everytime I've opened a cooling sytem Ive had to bleed the air out.
Old Apr 9, 2013 | 06:28 PM
egroegart's Avatar
The 3/4 mark is nothing to be alarmed about. that's where ours has run ever since we bought it.
Old Apr 9, 2013 | 06:38 PM
youngone's Avatar
Really? This is my sisters car and I'm not familiar with it, and asking her is pretty much pointless.
The last thermostat was stuck open so it never reached operating temp so she said the temp gauge "read low."
Old Apr 9, 2013 | 07:32 PM
egroegart's Avatar
Yes, if you do a search you will find other posts about this. That's in the normal operating range.
Old Apr 9, 2013 | 08:58 PM
youngone's Avatar
Son of a gun! Thank you Egroegart! I would of spent another day pullin my hair out!
Old Apr 10, 2013 | 12:29 AM
rsc's Avatar
rsc
To burp the H3 radiator you are gonna have to get the front end waaay up in the air to get the fill cap up at the highest point in the system. just parking the front wheels on a curb won't do it. Or so I have been told. However, running at 3/4 on the gauge at 100 degrees outside is about normal for many.
Old Apr 10, 2013 | 09:41 AM
happythree's Avatar
i think someone posted that you can get the actual temp from a scan tool??
i'll check mine later.
ultimately its the tstat that determines the temp
Old Apr 10, 2013 | 10:16 AM
06redhummer's Avatar
I hardly think 3/4 is normal range. I just changed mine out 3 days ago and couldnt get my to burp either. Before I changed mine it always stayed right at 1/4 on the gauge. Why would this be any different? I changed it do to codes showing up and I'm at 90K. So, I thought I would start with the cheapest of the 2 codes that came up. Engine light still on! How do you reset it or should I go ahead and replace the temp sensor? TIA
