-   -   Largest tire/wheel on an 08? (https://www.hummerforums.com/forum/private-sale-trade-classifieds-10/largest-tire-wheel-08-a-15850/)
SD90 May 27, 2009 09:36 AM
What is the largest tire size I can get on an 08 H2 without a lift and without rubbing?
Circuitguy May 27, 2009 11:11 PM
Its the same for all H2's 03 thru 09. Anyting above a 35" will tend to rub depending on the wheel offset you choose. Most popular are 20" wheel with a 325/60/20 tire or a 22" wheel with a 325/50/22 tire.
bflorin May 28, 2009 04:30 PM
I can tell you 37's w/ 20mm offset are not even close to fitting....
****..now I need to buy a lift...
Quijy Jun 4, 2009 08:00 PM
I have 35s, they fit fine.
fcfanatic Jun 5, 2009 07:19 PM
I like 20" we also have them on the BMW carswe have in the X5
They look the nuts and the price of the tyres are better.
pteam Jun 6, 2009 03:34 PM
35's are the size of the standard hummer rims and tires I believe.
HumminNBoatin Jun 8, 2009 09:20 PM
37x12.5x17 BFGoodrich tires KO's or KM2's fit on stock rims without issues at all. Only rubbing is on the swaybar causing no damage to tire or truck. Its when you go to a wider tire that you start having the rubbing issues. I had the BGF KM's in a 37" size with no problems. I now have the Toyo M/T and they are 13.5 wide They rubbed untill I did a slight lift.
So the answer to this question is Yes you can fit a 37x12.5x(what ever wheel size you want) "mine are 18's" without rubbing issues.
