Key won't open door on H3 2006
Old Nov 30, 2015 | 12:27 AM
Zeats's Avatar
Default Key won't open door on H3 2006
Battery is dead. Fob won't work. Key won't turn left. Although the key will turn right, nothing happens. Won't unlock. I can't get into vehicle. Ideas?
Old Nov 30, 2015 | 08:32 AM
Did you buy it used? If you know the key is correct for the door, then lube the lock and try again.
Old Dec 1, 2015 | 08:07 PM
rsc's Avatar
rsc
Hook a 12v power supply up to your towing wiring harness, slowly charge the battery through there. When battery charges enough use the fob.
Old Dec 2, 2015 | 10:33 PM
Zeats's Avatar
Thanks Doc Olds and rsc.
Yes, I just bought it used. 99,000 miles, 1-owner, $14K
I lubed the lock and then key opened door. When I tried to start the engine, battery was dead and key was stuck in the ignition. Then jumped the battery, let it juice up, and the key could be removed.
Next, I'm having a new battery installed, adding Stinger terminals, and a battery maintenance charger (1.5 volt) that I can plug into my garage outlet, for when the truck is not driven. Thanks again for quick replies!
Old Dec 3, 2015 | 08:11 AM
Sounds like you have it covered. Good news.
slider28
Sep 27, 2014 05:11 AM
johnmully
Sep 14, 2013 11:51 AM
maxjoann0120
Jun 16, 2011 05:15 PM
FurbiesAndBeans
Jun 9, 2010 10:58 AM
Hurst
Nov 1, 2009 05:14 AM
