I've searched with no luck.
2006 h2 air ride. I can't really find any threads with the same symptoms as mine. Im in the middle of a drive from California to south Carolina. About 800 miles in, u started getting the "service air suspension" warning. This happened for the following 800 miles. No drop in the rear end. No leaking down over two nights now. Yesterday I did crawl under and just wiggle some of the push connectors above the compressors and it actually almost didn't come on more than two or three times in 100 miles. This morning it's back on every few minutes. Do you think the connection is loose (I hope) and if it is, can I spray with electrical cleaner with no problems? Also, if it's not dropping, do you think it's okay to drive the last 18 hours to get home with worry? Thanks for any help or opinions.
