Interior "cracking" noise
I wonder if anyone else has had these problems and if anyone knows of a fix. Whenever someone holds on to the door pulls (not the handle to open the door) it makes like a cracking type noise. I don't know how else to better explain it but I believe this issue has been talked about before. Does anyone know of a fix for it? Sounds pretty cheap [:@]
RE: Interior "cracking" noise
is it the plastic on the door that you hold?
because if your pushing against the plastic and it makes a craking popping noise one of its clips might be damaged or broken causing it to move agianst something else or comin out of it fixed position creating that cheap craking noise you have.
I believe its coming from the plastic, but I don't think any of the clips are messed up...?
Don't give anyone RIDES!!![8D];)
Haha whata help you are, Bob [8D]
if its not the clips , check if nothing unordinary is touching the panels other than that idk
It looks like the plastic is touching the plastic and theres nothing in between as a buffer...? Any recommendations
Maybe buy some felt or something similar to put between them? I'm TRYING BUDDY!!!;):D
Haha, now you are! :D
