i need some help
Old Jul 13, 2006 | 03:34 PM
shortbus's Avatar
Default RE: i need some help
they're the side post type that screw into the battery, but i'm basing cleanliness on visual inspection only. it won't hurt to take them off and add some vaseline anyway. i just need the motivation.
Old Jul 13, 2006 | 06:50 PM
Dennis's Avatar
Good...Hit the faces of the posts with a wire brush while you're at it..
You see DC current is real suseptable to interuption by the littlest bad connection...That's why some lighting problems on cars (dim or out) are more than likely bad or cruddy ground points...The connections to the battery are also a weak point and need good clean contact to pass all the current the battery can deliver on start up...A bad or corroded connections is like a big resistor and it will also get hot.
Good luck..
Motivated?..Try 102 heat..Man it's so damn hot right now, that the garage is like an oven.[sm=badbadbad.gif]
Old Jul 13, 2006 | 07:59 PM
shortbus's Avatar
only 98 today. supposed to break 100 this weekend. but it's a dry heat, so 105 only feels like 104, damn near need a jacket . .
Old Jul 13, 2006 | 10:58 PM
Linus Gump's Avatar
Ok, so we want to talk about heat now, huh? Try 135 in the shade, a kevlar helmet, and body armor that weighs about 20 lbs and a 30 lb machine gun with another 15 lbs or so of ammo, then you mount up into your truck, and with the engine runnign and the transmission working hard with the weight on the truck, the cab is now well over 150, but you still have to keep your gear on. Temps like this and you are looking for a coat at 105. 90 and you are freezing.
just a little prespective of what our troops live with.
Old Jul 13, 2006 | 11:06 PM
Dennis's Avatar
Yeah you're right..forgot about what real damn heat is all about..
And not to mention dealing with these God forsaken camel spiders while you're trying to sleep...
dilo2001gt's Avatar
What year is it
Old Jul 13, 2006 | 11:09 PM
Dennis's Avatar
Last time I looked it was 2006..Why?
Old Jul 14, 2006 | 09:29 AM
dilo2001gt's Avatar
ha ha i meant shorty bus[8D]
Old Jul 14, 2006 | 01:34 PM
shortbus's Avatar
year? i'm confused, but that's not hard to do.
Old Jul 14, 2006 | 01:47 PM
Dennis's Avatar
I think he meant the year of your; Either Battery or the Bus
