Hummer H3 Tires
I am looking for some recommendations on some tires for the hummer h3 ... I am looking for some tires with a great "knobby" look ... tires that will fit a stock hummer h3 ... I like the "mudding" tires ... I want something that can be driven on the streets with no issues ... but something with some real grip! Anyone have suggestions and pictures?
OP, why do you want knobby tires for the street? Are you doing off roading?
I ask because the life of your tires will stink & if they don't have sipping, good luck with traction in wet environments.
Toyo AT2s are too heavy. LT315/75R16 is 72 lb each (for 17s, they are 70 lbs, but 18s are 81 lbs; I don't get it). The Duratracs are 64 lbs each in the same size. Heavy, but 8 lbs each is a hefty chunk to take off. Your drive train will suffer with so much weight from the toyos. They are LOUD too.
