Hummer H2 with Cummins 6bt power steering fluid question
Old Jun 5, 2019 | 05:07 PM
Rojolo's Avatar
Default Hummer H2 with Cummins 6bt power steering fluid question
Greetings everyone.
As the title states, I have a 2004 Hummer H2 with a cummins diesel conversion. I am in the process of replacing the power steering pump and would like to flush the system. I'm just not sure if I should use what GM or Cummins recommends as they can be different.
I want to use GM recommendations as it is "power steering fluid" as opposed to atf for cummins.
thanks
Old Jun 6, 2019 | 07:07 AM
fastNYsix's Avatar
I have ran atf in my GM vehicles before without issue. Can you post some pics of your H2 please? I'm interested in this swap.
Old Jun 6, 2019 | 07:19 AM
calif phil's Avatar
Both fluids will work fine. I use the PS fluid because it's normally cheaper than ATF
Old Jun 6, 2019 | 09:57 AM
some say power steering fluid takes a bit more heat from the hydro boost system than transmission fluid will but i do not know if that is a real concern.
Old Jun 7, 2019 | 08:20 PM
Rojolo's Avatar
Thank you for your replies - I have atf from my tranny fluid change so i'll use that.
I picked the hummer up as a runner with many problems to solve. A Duramax diesel conversion seems more plug and play whereas the cummins is pure caveman!!!
oceanbrave
Jul 18, 2017 07:03 AM
BlueH3
May 16, 2015 08:05 PM
tx_pilot
Nov 29, 2010 12:17 AM
worknit
Jun 8, 2010 12:58 PM
uzz32soarer
Oct 30, 2009 08:15 AM
