-   -   How to replace cabin air filter (https://www.hummerforums.com/forum/private-sale-trade-classifieds-10/how-replace-cabin-air-filter-17461/)
atashashane Nov 18, 2009 06:59 PM
Hi Guys, I just find out this video on how to replace cabin air filter. Its relatively simple repair that can be done in a few minutes. I just don't know if that will work for hummer? Any suggestions? Thanks.
calif phil Nov 19, 2009 10:20 AM
If your Hummer has one it's inside the H2 on the lower portion of the right side dash. The filter sits verticle.
D VADER Nov 23, 2009 04:10 AM
The H3 doesn't have a cabin filter. :(
2wheelmonster Nov 24, 2009 04:17 PM
The only filter that the cabin might have is probalby in the fire wall where the blower motor gets air from
zombiember Dec 2, 2009 12:17 AM
Replacing your car's air cabin filter is a relatively simple:
1. Remove the main access cover, undo the cover fasteners to remove cover and side cover if needed.
2. Locate and undo retainer clip to remove air cabin filter, compare the filter size to the replacement filter and reassemble.
D VADER Dec 2, 2009 05:46 AM
You must be referring to the H2 as the H3 has no cabin filter.
jurelut Dec 17, 2009 07:28 PM
I am a non-smoker. The filters were pretty clean at 30K miles. You could hold them up to the light and see quite well through them. In fact I've set them aside for possible re-use.
The climate in New England is not very dusty and there are few gravel roads. I was not having any problems with feeling the AC, either. The reason for erring on the side of preventive maintenance was concern over getting my allergies riled up.
A friend who has a Subaru shared a similar story about his cabin air filter.
KineIntiz Feb 13, 2010 02:38 AM
Thanks to acai berry juice, after 41 years, I'm no longer a smoker!
D VADER Feb 13, 2010 06:26 AM
But you still SUCK!!
Krod1181 May 29, 2018 11:02 PM
Hahahaha, wherr in new England do you live? I assure you, there are more dirt roads in new england than there are paved suburban area. You should take your truck on some adventures as it was built to do, leave your suburb in CT or Andover and drive a couple hours west or North and i assure you... YOU WILL find dust and dirt. My H2 gets dirrty. #useyourtruck
