Hot temps
Old Aug 8, 2006 | 01:00 PM
topcarbon's Avatar
Default RE: Hot temps
26 days of heat is nothing to boast about. I think here in Phoenix we have had 100s since May. Although we experienced a cooling trend where the temps only reached 96 as a high. Yesterday at 9:00 am it was already 93. Good thing my Hummer runs cool.[&:]
Old Aug 8, 2006 | 01:21 PM
HummerGuy's Avatar
Another Theory to offer:
It may not be a defect. Many times (especially with GM) certain batches of cars are produced with certain specs.
Example:
H3's produced that will be shipped to the northern, cooler parts of the US may have been intentionally produced with the Higher temp thermostat's to keep the engine warmer, where as the H3's produced to be shipped to the southern states may have the cooler opening thermostats to keep the engine cooler.
Now, knowing GM, they may have botched the orders, and shipped the Northern H3's to the south, and vice versa, OR, because they are in such financial crunches, decided too late that they need to fill orders and just ship them off wherever they were needed.
If you are a gearhead, changing the thermostat shouldn't be too hard. I know there are sites that offer the different temp thermostats for the H3.
Old Aug 8, 2006 | 07:36 PM
ChevyHighPerformance's Avatar
Find someone with an OBD2 scanner and read the ECT. If it is the same as the temp gauge, independently check engine temperature. This just makes sure that the engine is actually running hot versus an indication/sensor problem. This isn't a complete diagnosis for the high temps.
Old Aug 8, 2006 | 09:11 PM
SedonaBoundH3's Avatar
The temp gauge never budged above "well warmed-up", regardless of outside temp or load in my previous several vehicles. With the H3, the temp reading fluctuates (above a midpoint) depending on the outside temp and load. Even though its a long way from the top of the gauge, I'm uneasy seeing the needle climb from a "normal" position when then outside temp gets hot or driving up a long grade. It seems to me the cooling system should be able maintain a stable temp for anything the typical driver can throw at it. Next time its in for service, I'm having the dealer check it out.
Old Aug 10, 2006 | 01:31 AM
Grand's Avatar
Just got my computer back up and running. Thanks for all the input. I will call the dealer and have them check into it.
RJ3607
Nov 18, 2014 08:28 AM
09 Black H2
Aug 25, 2014 06:29 AM
H2CANEPADESIGN
Jan 10, 2013 08:50 PM
kchummer
Aug 18, 2009 02:34 PM
RealJeep
Dec 16, 2007 10:44 AM
