HELP! oil leak on top of steering gear box or transmission/steering line?
I noticed that the top of my steering gear box is wet with oil. However I beleive it's the transmission oil cooler line or is that a steering hose line? which runs directly over on top of the steering gear box and goes into the radiator and at that particular area of the steering box on the hose it appears wet as well. I gave all the bolts on the steering gear box a good tug with a ratchet and socket and nothing budged, indicating that all the bolts are tight. Could it be that the hose is sweating or leaking? Or the steering gear box is faulty?
Old post with no replies but for future reference.... sounds like the oil cooler lines. They are prone to leak. I used a block off plate. I also developed a leak in the left side oil pan. This tends to be a big problem with these motors.
Please do not make a habit of digging up OLD as dirt threads for "future reference".
Thank you in advance. |
(Post 336857)
Thank you in advance. Thank you in advance |
Mad Mike, Can you Enlarge your avatar please?
