HELP! With Adding a New Horn
I just bought this new horn from Amazon: Amazon.com: Wolo Model 519 Bad Boy Chrome One Piece Design Air Horn Kit - 12 Volt: Automotive, and I was wondering how do I install it, I think I need to remove the front bumper to get to the factory horn. Any help will be greatly appreciated!
Oh sorry I meant grille not the bumper. But, how do I remove the grille so I can get to the factory horn?
You really don't need to take the bumper off, the grille would help, but still not needed... You can use the factory mount for that, unbolt it and use the wires for that one... Should work or may need the relay...
Didn't your new horn come with instructions? The horn if to the left of your hood latch assy. It's probably easier to access/replace with the grill off.
Use the search tool in the upper right corner of the H3 sub section... There's only 4 bolts that hold it on... Kinda scary the first time you remove it though... Alot of snap in tabs that require a little elbow grease to get it to Pop free...
