Head lights
Old May 17, 2013 | 01:06 PM
staggs's Avatar
the hi/low kit should Come with a harness.
do not need error cancelers
mounting is up to you. I have mine zip tied in the engine bay, it all depends on how you want to mount them.
Old May 17, 2013 | 01:07 PM
sneakypigeons's Avatar
i dont know what the error cancelers are but the other two things should come with the kit already. you do need them, more the wire harness then the mounting kit. i didnt use the mount brackets on my ballast. i just let the set down on the little 'shelf' area by the headlights.
Old May 17, 2013 | 02:15 PM
Hummer72's Avatar
What is and what does the error canceler do??? Sounds important.
Old May 17, 2013 | 02:37 PM
EvanMEllison's Avatar
It cancels errors
Old May 17, 2013 | 02:44 PM
When a HID kit is installed in newer car models or cars with a computer controlled unit, often there is an error code showing on the dash board or the HID lights keep flicking and would not stay on. This is due to the fact that the HID kit is triggering a bulb out warning signal in your car's computer control unit. By connecting a HID error canceller, the capacitor in the device balances out the current draw of the HID kit and would offset the warning signals.
Old May 17, 2013 | 02:45 PM
Hummer72's Avatar
Really hummm figured that much out. But is the HID lights gonna cause me to have errors?
Old May 17, 2013 | 02:46 PM
Hummer72's Avatar
Well do I need one???
Old May 17, 2013 | 03:00 PM
why did you ask if you already knew what they were?
Simple solution for you:
1- buy your hid kit
2- install
3- test
a) no errors, no flickering; NO EC's needed
b) errors or flickering; EC's needed
simple plug and play if you need to install the error cancellers, connect one end to the HID bulb and another end to the ballast.
Old May 17, 2013 | 03:07 PM
none of my kits ever came with an error canceler and i've installed them on a lexus es300, a bmw 325, and a hummer h3. none of which ever threw a error code. i think youll be all set with out it.
Old May 17, 2013 | 03:10 PM
Hummer72's Avatar
That response was for Evan not anyone else. I really appreciate all the help with this. Keep talking I am listen...
