Has anyone used Sunroof wind deflector?
Has anyone used the Bene Vento Sunroof Wind Deflector? This is one of the few that I have found that does not use tape, it has clips instead. I'm wondering about quality and wind noise.
RE: Has anyone used Sunroof wind deflector?
http://www.autoanything.com/deflectors/69A1308A0A0.aspx
This is the one i have it vry strong. Then they came out with the clips http://www.autotrucktoys.com/hummer/...9120C1331.aspx |
Did you notice any reduction in wind noise with the deflector?
I got the Bene Vento...scratched the hell out of the sunroof lip putting it on. The bolt and screw are barely long enough to clip on, takes a little manipulating. Looks good and cuts down the wind noise.
The cure for open sunroof noise.Crack your back window.Works every time.
Not sure if all hummers are the same but when my roof is sliding back in Auto mode the stopping point keeps the noise right down, but if i fully open it the back window trick can't be beat :eek:
I have the one from truck toys and love it! The bolts and nuts that came with it are to short like mentioned above. I used ones that were a little longer. As far as wind noise big difference. The H2 comes with one from the factory for a reason.
