H3T Water Possible sunroof drain question...
Hi room,
It's been a while since I have been on the forum and posted. Since my last post I traded my H3 for an H3T - great truck! I have noticed that if my car is parked, and A/C has not been used, there is sometimes a puddle under the right front (near the tire) where there would be a water puddle had the a/c been used. Spoke with the dealer and they said that it could be if I used the front windshield defroster... but I hadn't. Most recently, I took it for a wash, drove it about 100km after in dry weather and then parked it for the weekend in my garage. 2 days later there was a puddle and dripping from my vehicle in the morning. I am thinking maybe the sunroof isn't draining properly, although I do hear it drain during a car wash or if rain. Any ideas/suggestions? Thanks, /Mike. |
when i got my h3 "skylite" i tested it to see how/where it drained.
i parked nose down hill and poured a cup of water in the front,left,then right ,to see it flow thru. then parked nose up hill and did the rear. all 4 corners dump out by the wheels behind the fender liner. if yours dont drain in one corner , u gotta look under headlineror ? for a bad/plugged hose there have been posts here about that |
Thanks for the reply. Dealer checked it out. Says all drains are clear... They said there is a spot where water can accumulate on top of a frame rail so this is likely it. Cab seems to be dry so I hope all is fine. I did notice in the past that the skid plate would retain water sometimes, so maybe it's a similar situation..
| All times are GMT -5. The time now is 04:45 AM. |
