H3 Parasitic Drain (Nearly All) SOLUTIONS!!!
Y’all!! I want to post this because I want to save everyone the amount of time that it took me to FINALLY figure out my Parasitic Drain. Thanks to lots of help here from Lots of folks I decided it would be a good idea to just post a list of all the things I checked. 1) OEM Connectors 2) Wiring Harness in the back with the door open. Look for exposed wires because the harness is too short. This was one of my issues. 3) XM/OnStar Module - Another one of my issues 4) The BCM due to leaks from the sunroof. 5) Fuel Pump Relay 6) Door Jams (allowing power to remain on even if door is shut) 7) BIG ONE of my issues... 6Disc Changer was continuing to run ALL NIGHT LONG. Anyway i I hope this helps folks so they can kind of have an idea what to check without searching thru older threads. Good Luck! As DOC says Electrical Gremlins are the WORST!!! XO GINNYH3 |
