H3 LS Conversion from 3.7L - HELP!!
Hey guys i posted in the wrong section before and was chasing more detailed instructions.
So I'm pulling the 3.7L engine out and replacing with an LS, I think here in Aus i should be able to almost get away with it cheaper than replacing with standard but just to make sure I get the right parts i'll need; LH oil pan / engine mounts/ loom/ ECU is that all? will i need to change the box to suit or...? Any help would be much appreciated and I thank you for your time! |
Originally Posted by Lukijoos
(Post 323849)
So I'm pulling the 3.7L engine out and replacing with an LS, I think here in Aus i should be able to almost get away with it cheaper than replacing with standard but just to make sure I get the right parts i'll need; LH oil pan / engine mounts/ loom/ ECU is that all? will i need to change the box to suit or...? Any help would be much appreciated and I thank you for your time! Here ya go: New motor |
Your bad a*s in my book for doing the swap - I hope you post progress and pics :)
