H3 factory upgraded using low mileage 2012 colorado truck
I have pulled out all these parts off the chevy colorado that was rolled while in tow with 9400 mile on it. Does anyone have any knowledge to add or wish to find out as we do the 300 hour project in our boat shop.
Report from boat yard san diego's engineering dept: Hummer H3 2007 parts that seem equal and a direct swap with chevy colorado parts: 2008-2012 main engine tranny fuel and hydraulic lines wiring harness front differential and truck switch to disable AWD front brakes front axle front shaft exhaust, both old a new were cracked behind heat guard, if you smell exhaust take it off and grind it out then weld. front seats dash gauge cluster steering wheel and key stereo, speakers overhead cabin lights radiators and evaporator alternators HVAC Computer ECM Heating fan fuel lines steering rack and pinion front and rear differential gears |
Many of the parts listed will not directly swap to an H3. Good luck with the adventure you are about to take on.
| All times are GMT -5. The time now is 06:56 AM. |
