H3 driver side window and doors lock
hi,
i have problem with my 2007 H3. Doors lock doesn't work and driver side windows are not working too. Keychain doesn't work too. i have tried: -pulling out fuse 8 and 68 -taking out control panel and checking if it has dust or something -disconnecting battery for 30 minutes for computer to restart (computer restarted(my keychain signal was lost but I programmed it again)) those methods didn't work i saw that my keychain trigger anti-thief mechanism but no door lock i also saw that I can program door lock in computer. To do that you need to hold door lock button on control panel for 3 sec with key in lock position. So door lock button is working but doors lock mechanism isn't working i don't know what to do because I live in Poland so I can't give it to dealer. thanks for help |
Check battery terminals, and battery. If battery goes below 12 volts it will cause this issue. Once you change battery the lock and window with will reset.
I have replaced old battery with brand new but it has not changed anything. Terminals are ok. :/
Originally Posted by Szafer128
(Post 341845)
You should also use the SEARCH function here. https://www.hummerforums.com/forum/h...working-14696/ |
