H2 won't start
Old Nov 1, 2017 | 09:57 PM
KING TANK's Avatar
Default H2 won't start
I need help with 05 H2, when I go to turn it on it won't crank. Someone told me it was the ignition switch so i replaced that it wasn't. Then they said it was probably the the ignition assembly where the key goes so I bought that it wasn't. So we check all the fuses those are still good. Does anyone know what it may be.
Old Nov 2, 2017 | 07:52 AM
calif phil's Avatar
Check and see if you have power to the solenoid wire when the key is held in the crank position. It could be a starter. Have you tried putting it in neutral and see if it will crank then?
Old Nov 2, 2017 | 12:51 PM
KING TANK's Avatar
no I haven't I will try that when I get out tonight. All it does when I insert the key and turn it is make 4 light sounds clicks.
Old Nov 2, 2017 | 01:15 PM
LennyLexx's Avatar
Just for ****s and hummer giggles, turn on the headlights and then the key. Could be battery
Old Nov 3, 2017 | 09:27 AM
KING TANK's Avatar
Not the battery lights turn on inside lights turn on. Horn works battery dosent die.
Old Nov 3, 2017 | 12:56 PM
I wonder if you need to do a security relearn..... Google GM truck security relearn
Takes about a half an hour (unless you happen to have a GM Tech2).
Old Nov 9, 2017 | 09:19 AM
KING TANK's Avatar
I have tried that still nothing. I got it to start but now again it won't crank, the relay wasn' telling the starterto start after turning the key. So i had to do was turn the key all the way, then goto the relay to pinch it and it started . But not it' not doing nothing . Again
Havanadaydreaming
Hummer H1
Aug 28, 2020 02:15 PM
HumRluvR
May 31, 2016 07:53 AM
Bamaboyz79
Jul 2, 2007 03:51 PM
deborah
Mar 3, 2007 07:09 PM
wilesrh
Feb 17, 2007 08:19 PM
