H2 Speedometer not working
Any suggestions how I can fix this myself? I have a 2003 H2. Needle is not moving at all, stuck on the bottom.
Thanks so much. Kim |
I have a used cluster out of a 2003 H2 in perfect working order for $175
There was a TSB on this. The whole cluster needs to be replaced. Mine had to be done as well. You will have to take it to the dealer as I will need to be programed to your BCM it's not just a plug and play install.
I purchased a used one (in Km's) & had it programmed to my existing milage , swapped it out with no issues
All too COMMON of a problem!!!
