H2 died ???
Old Dec 16, 2013 | 01:41 AM
Captchee's Avatar
Default H2 died ???
hello , im new to the forum and new to the hummers . my wife and i just bought a high mile, 2003 H2 a few days ago
. love it. it appears to have been well taken care of and is very clean .
I was driving home tonight and it lost power , I pulled over and it died . Tried to restart it. Turns over fine , everything comes on but the engine acts like its out of fuel .
I let it set for a few minutes and tried again , it dries to start but dies .
I been reading about the issues with the anti theft thing , but im wondering if that would be an issue since I was actually driving it for some 30 minutes when it happened .
Im thinking fuel pump but im just not very knowledgeable about these yet .
Any help would be appreciated
Old Dec 16, 2013 | 11:11 AM
dr.drew2's Avatar
Default fuel pump
check fuel pump. in gas tank. that should solve problem to replace
Old Dec 16, 2013 | 01:51 PM
calif phil's Avatar
Sounds like a fuel pump to me. Make sure to buy a quality pump (Delphi) There are a lot of cheap fuel pumps on the market.
Old Dec 16, 2013 | 03:30 PM
budryzer's Avatar
X3 on the fuel pump I haven't tried it on my hummer but if you have two people, one by the key and one at the gas door..... You take the cap off and listen for a whine when the key is turned to run. Not start, just run. Electric fuel pumps pressurize the system before starting
Old Dec 16, 2013 | 04:21 PM
Captchee's Avatar
thats another reason i thought i was probably the pump as i couldnt hear a 3 sec buzz . but then i dont hear so well anymore so .
thank you all for he help
Old Dec 18, 2013 | 12:17 PM
strippersteel's Avatar
My guess is fuel pump as well. Let us know what you find out.
Old Dec 18, 2013 | 08:35 PM
Captchee's Avatar
Well I ran some electrical tests just to make sure . I was indeed getting power to the pump but nothing from it. Yep it had seen its last days . So I replaced it . My H2 started right up
Old Dec 19, 2013 | 06:51 AM
That's good news. Glad you got it fixed.
Old Dec 20, 2013 | 05:09 AM
budryzer's Avatar
SWEEEET On to the next I have my own water leak issues
Old Dec 21, 2013 | 08:39 PM
2004H2's Avatar
get a tube of clear silicone,use it around the lights front rear and check for the rubber gromit on drivers side lamp with phillips screw holding the lens,check to see if there any holes open to the liner of the truck and seal them...with the clear,silcone..........Good luck,done mine already......was leaking water thru the on-star speaker in liner......all dry now )
Rick H2/H3
indyh2
Feb 1, 2008 05:01 PM
HummerGuy
18
Jan 25, 2008 10:21 AM
HummerGuy
Oct 16, 2007 03:08 AM
HumV
34
Jul 20, 2007 10:58 AM
Sugardaddy
Aug 18, 2006 11:23 PM
