Groaning front driver front area
Looking for a little help here, but I know diagnosing sounds on the internet can be pretty tough.
I have an '03 with 60k on it and when I turn the wheel to the right when moving (at any speed), I have a groaning/squealing sound from the driver's front corner area. It does it almost all the time if it's raining out, and when I first start driving. If it's not raining, and I've been driving for 10 or 15 minutes, it stops doing it 99% of the time. I know it's not any kind of rubbing or interference issue because I have looked for areas it could be rubbing and it happens whether the wheel is barely turned or turned all the way. My first thought is the wheel / bearing in that wheel is going, as I think I remember that being a pretty common problem on H2's. I just don't want to oder a new bearing if there is something else that this probably is or another common problem that I haven't heard of. Any input is appreciated. |
define squeel? like a belt squeel? or a bad brake squeel?
have you jacked that front end? can you wiggle the tire up and down? is your caliper intact? What does the rotor look like? |
Nothing like a brake or belt squeel. Much lower pitch.
That's why "noises" are so damn hard to diagnose over the internet. I ordered my new air bags for the rear suspension yesterday, so when I run it over to my mechanic to through them in, I'll him look at it. Thanks for the reply though. I really assume it's the bearing, but didn't know if there were other common issues. There's no shaking in the steering wheel or anything like that either. |
you have the hub, and you have the halfshaft.... either could make noise...
let us know though what the mechanic sees...says.... second opinion.... etc... |
I would be happy to look into this for you as well of you are not able to resoled the concern. Please feel free to contact me with more information. Thank you.
Tricia, GM Customer Service. |
yeah.... I bet all he needs to do is send you his VIN....
LOL.... |
Originally Posted by GMCustomerService
(Post 261711)
Interesting! Thanks for the heads-up guys!
I have not been a member long but all I read from tricia @gmcustomer service is the same
"I would be happy to look into this for you as well of you are not able to resoled the concern. Please feel free to contact me with more information. Thank you. Tricia, GM Customer Service. " |
Originally Posted by TowDawg
(Post 261344)
I have an '03 with 60k on it and when I turn the wheel to the right when moving (at any speed), I have a groaning/squealing sound from the driver's front corner area. It does it almost all the time if it's raining out, and when I first start driving. If it's not raining, and I've been driving for 10 or 15 minutes, it stops doing it 99% of the time. I know it's not any kind of rubbing or interference issue because I have looked for areas it could be rubbing and it happens whether the wheel is barely turned or turned all the way. My first thought is the wheel / bearing in that wheel is going, as I think I remember that being a pretty common problem on H2's. I just don't want to oder a new bearing if there is something else that this probably is or another common problem that I haven't heard of. Any input is appreciated. I'm new here but I was doing a google search and happened upon this forum and I have this exact same problem on my '03. If you get an answer please post. I asked someone I knew and they thought it might have to do with the CV joint on the drivers side. I just haven't had the time to follow-up with it. |
