Go big or go home (Hummer H2 12")
Quick Overview
All parts are covered in high quality gloss black powder coat (color upgrades available).
Improved ride and handling from factory. No welding required our kit is designed to be entirely "bolt on". Factory wheel base and track maintained.
All Bulletproof manufactured parts are covered by a lifetime transferable warranty.
Why Choose A Bulletproof Suspension Lift Kit?
Let the team at Bulletproof Suspension Inc. get you on 40-44" tires up to 15.5" wide on your Hummer H2.
This kit created the catch phrase "go big or go home". Bulletproof Suspension Inc has designed this Hummer 12" Suspension System with the leading design and engineering that can only come from Bulletproof Suspension. Inc. Our Bulletproof Suspension H2 lift systems is one of if not the most popular H2 Kit available on the market today. Tried, proved and tested, this is the only 12" lift system for your H2. All components are made from A36 steel plate 1/4" thick or thicker and heavy wall D.O.M.(drawn over mandrel) seamless steel tubing. We use continuous seam welding with gusseted truss type construction. We call it "Bulletproof" because it is.
Our services
Bulletproof Suspension Hummer H2 12" kit maintains factory wheel track width and wheel base and there's no need for cutting off the main factory boss on the differential like on other H2 lift kits either. We here at Bulletproof Suspension know that being able to return your truck back to stock is essential to the re-sale value of your vehicle. In addition, both the steering and differential are dropped down not just left in the factory position as on some H2 kits. This prevents any extreme angles and maintains the factory geometry while still achieving up to 12" of lift with no axle spacers (ask the other guys if they can do that!) The kit also comes with complete instructions with photos and hardware kit labeled for each step of the installation.
Six shocks are required and we offer Standard Shocks or Fox Racing Shocks and are quoted separately. Uni Ball A-Arms are also available as an up-grade for this Hummer H2.
Contact with us:
Address:
1316 Agate Avenue, Suite-E
Mentone, CA 92359
Phone:
(909) 389 0444
Our services
Contact with us:
Address:
Mentone, CA 92359
Phone:
(909) 389 0444
BrianSF-GA
19
Jan 2, 2013 06:52 AM
FilthyKings
May 17, 2012 08:15 PM
schmegeggie
Mar 11, 2009 11:33 AM
