Gear Shift Button Broken - H2 2005
Old Dec 29, 2013 | 04:10 PM
mrjohnp's Avatar
Default Gear Shift Button
The button on the Gear Shift handle is loose
I have a replacement.
Does anyone know how to take the button off or is it easier to change entire shifter?
Old Dec 29, 2013 | 04:22 PM
LoJac963's Avatar
I've never seen a thread of any hummer forums of someone taking the handle apart. Not saying it can't be done but with as rare a piece I don't know if I would risk trying to take it apart myself without knowing exactly how.
Old Dec 29, 2013 | 04:31 PM
mrjohnp's Avatar
All fixed now.
Old Dec 29, 2013 | 06:11 PM
bad70ss454's Avatar
Old Dec 30, 2013 | 12:15 AM
LoJac963's Avatar
Turn the key so you can pull the handle down into the lower gears (truck does not have to be running) and you will see an allen screw inside the vertical portion of the handle. You don't need to take the screw all the way out just back it out enough and the handle will slide off vertically.
Old Dec 30, 2013 | 04:12 AM
bad70ss454's Avatar
It's a torex screw but make sure you get it really tight when putting it back on or you will get movement in the handle.
Old Dec 30, 2013 | 01:12 PM
LoJac963's Avatar
oops you're correct it is a torx however you don't want to overtighten it. Snug is good.
Old Dec 31, 2013 | 06:35 AM
budryzer's Avatar
I had the same issue with the one tab broken off. They will snap back in when they are both good, so I would think you could pull the button straight out. I just carefully crazy glued my button back in to the white plastic inside the handle. It's worked for this month
Old Jan 20, 2016 | 03:49 PM
trek5866's Avatar
Hi I looked but couldn't find it. I have an 06 H2. Any help would be appreciated.
Thx
Old May 25, 2016 | 07:50 PM
Spark1's Avatar
Default The same problem.
I'm glad you fix it. I have the same issue, how you did it please?
