Fuses
Is there a fuse block, when you open the driver's door, on the side of the dash? If so, how do you access it? I assume you pull on the plastic piece....but I don't want to pull it to hard....
RE: Fuses
Yeah it is held in with 4 clips... one at the bottom where the picture of the fuse is... 1 in the upper middle and two at the top by the hole
RE: Fuses
Pull at the bottom and if you look you can see the one clip. Then work your finger or a trim tool in there and pop the top ones. It fits very snug.
RE: Fuses
thanx Stan.....snug isn't the word for it....
RE: Fuses
more like impossible!:D
RE: Fuses
Those clips are pretty strong. As long as you pry out and not at an angle you shouldn't break them.
RE: Fuses
BTW... your spare fuses and fuse puller are mounted on the panel inside.
There is a big fuse box under the hood by the battery. Is there a secret to getting the lid off? I have tried and failed.
Bob |
