Fluids Changed - More for the recent owners
I had the transmission and transfer case flushed and serviced, performed a chassis lube and changed the differential fluids.
1. The transmission fluid looked ok; however, the transfer case fluid was dark brown. Apparently the previous owner never did the transfer case... 2. Lubed 11 out of 12 chassis points. Could not find the idler pivot point lube point. Used the entire grease tube on 11 points... 3. The differential fluids looked ok; however, when I transferred the fluids to a milk jug only one gallon was present - low fluid. If I were you I would check these out on your H2. Glad I did... Richard |
Great suggestion, Thank you!
UPDATE: Also had the power steering, brake system and coolant flushed and serviced today. All the systems looked good...
