Fixed rough idle
Old Jun 19, 2011 | 09:05 PM
bflank's Avatar
Default Fixed rough idle
So my 07 H3 was idling very roughly. I cleaned the throttle body thoroughly with almost no effect. From what I read I was thinking mass airflow sensor but since those are over $100 & the H3 was over 80K miles I decided to try a new set of plugs first.
I ordered a set of exact OEM replacement plugs from Amazon for less than $30. Putting them in was probably the easiest plug replacement of any vehicle I have owned. You do have to remove the air resonator box to access the plugs but then it's just one bolt to remove the coil assembly & pull the plug.
The rough idle went away immediately but the I5 ran sluggishly for about the first 5-10 miles. I am assuming the computer was adapting to the new plugs and readjusting. I will be interested to see if I get a slight mileage improvement over the next couple of tankfuls.
Old Jun 19, 2011 | 11:09 PM
How many miles are on your 07? Just for reference I was wondering what was the gap on the plugs you removed? Do you have pix of the old plugs?
Glad to hear your H3 is running better now!
Old Jun 20, 2011 | 03:57 AM
bflank's Avatar
I was right at about 83K miles. I didn't measure the gap since I was told the iridium plugs are not to be gapped, but I can probably get some pics of a couple of the plugs.
Llamafood
Jan 11, 2012 07:16 PM
IT_TORK
Nov 30, 2010 10:45 PM
demetri911
Feb 13, 2008 09:37 PM
brachilius
May 4, 2007 06:35 PM
ZX10R
Apr 27, 2007 10:46 PM
