Fan Control??
Is there any way to completely turn off the fan for the AC/vent/heater?? In my H3, even if you rotate the knob to the "O" setting, air still comes out of the vents.
RE: Fan Control??
I thinkthis was posted before, if youplace place the fan off and the Climate Control (center control knob) to recirculation, that should stop the air flow.
RE: Fan Control??
I know that H3 has a control set up like my chevy truck and as long as the control is set on anything but defrost setting you can set to recirculate and it will stop blowing thru.
RE: Fan Control??
That's odd...Mine turns off 2007 H3. Also the lights in the center of the knob are off.
RE: Fan Control??
Correct, Realjeep. The fan is off, but outside vent air continues to flow if you are moving, although at a low level. I noticed the same thing on mine. When I turn it to "recirculate," the outside vent air is shut off.
RE: Fan Control??
Thanks!! Oh dopey me......Never thought about adjustingany of the other knobs.[&o]
RE: Fan Control??
I had the same problem (on top of my laundry list of others) with my AC control on my '06 H3. Air would blow on "O", even when at a standstill. Dealership fixed it 4 times & it still didn't work right. Turns out I qualified for a lemon & traded it out for a new '08 H3x. Hope I have better luck with this one. Anyone out there also experience major problems with their '06H3? Here's my list:
Crack Cylinder Head Cracked Oil Pan Defective Gas Tank Air Vent Broken Seat Warmers Faulty Stability Control Sensor Malfunctioning AC Control System |
RE: Fan Control??
Damn........ Must have been a bad day on the production line.
RE: Fan Control??
You're telling me. Must have been a Friday!
RE: Fan Control??
ORIGINAL: fable123 I had the same problem (on top of my laundry list of others) with my AC control on my '06 H3. Air would blow on "O", even when at a standstill. Dealership fixed it 4 times & it still didn't work right. Turns out I qualified for a lemon & traded it out for a new '08 H3x. Hope I have better luck with this one. Anyone out there also experience major problems with their '06H3? Here's my list: Crack Cylinder Head Cracked Oil Pan Defective Gas Tank Air Vent Broken Seat Warmers Faulty Stability Control Sensor Malfunctioning AC Control System |
