Factory XM
Has anyone added a factory XM Module to there H2? I have a 2004 Hummer H2 with the NAV system but it seems as if it didn't come with the XM module. I have the Y91 code in the glove box. When I use the band button XM is not one of the options. Can anyone help?
Thanks Rob |
RE: Factory XM
ORIGINAL: hcso4704 Has anyone added a factory XM Module to there H2? I have a 2004 Hummer H2 with the NAV system but it seems as if it didn't come with the XM module. I have the Y91 code in the glove box. When I use the band button XM is not one of the options. Can anyone help? Thanks Rob Wendell |
RE: Factory XM
Thanks Wendell... I want the XM radio for mine.... Until I find it I am just using my Garmin Streetpilot 7500....
RE: Factory XM
Thanks Wendell... I looked behind the glove box and the bracket that it sits in is not there, also don't see the wires. So am I to assume that I will have to run all the wires including the antenna wire?
Thanks Rob |
RE: Factory XM
does gm make a upgrade for xm for 07 h3 mine did not come with xm and would like to add it on .:eek:
RE: Factory XM
no need to double post...I answered you question in the other thread you posted this in.
RE: Factory XM
Question: is there a way to retain the XM Satellite in an H3 if one is upgrading to an aftermarket DVD/nav system?
If not possible, then what can be done to the XM antenna? Can it be used for a portable XM receiver (such as Pioneer Inno or Samsung Helix)? Or can it be converted to act as an antenna for a cell phone, such as a GSM phone? What is needed in terms of adaptors or harnesses? |
RE: Factory XM
[:@]You can order the part #17803005 factory GM xm upgrade kit , I took my hummer to the dealer to have it installed and they charge me $269.00 for the labor , they did a heck of a job and now i have factory installed xm radio , the kit comes with a new ONSTAR/XM ANTENNA/GPS and it will replaced your old onstar antenna on the roof.......here is what i order the xm upgrade kit ....
www.gmaccessories.com ....... |
RE: Factory XM
GM does make the XM upgrade kit for the H3. I didn't look at the H2. I sell for less than the site mentioned.
RE: Factory XM
and/or....
If you need a good digital interface to also run XM and your iPod... http://stores.ebay.com/Integration-S...QQftidZ2QQtZkm I have one and it works perfectly... and the directions could not be better... |
