Factory Headrest Monitors & Audio
I just got a used 06 h2 and I'm soooo happy!!!!! I have the headrest monitors in it and I've been using the headphones to listen to my DVDs. How do I get the audio to play through the speakers so that I don't have to use the headphones?
RE: Factory Headrest Monitors & Audio
You should have an fm modulator that sends the signal direct to your stereo.
ORIGINAL: RonMan You should have an fm modulator that sends the signal direct to your stereo. pre-set station for that? |
On units I had in the past u could change the station in order to find an open frequency. Im waiting for a set I just bought so I dont know how you would do it to these. Mine are supposed to the have the instructions. Unless someone chimes in sooner then I can't help you till then. I'll keep checking back.
Run through your menu options and make sure the FM mod is turned on. Then find the FM freq on your radio. Mine was set to 88.7
