Ethanol Conversion Kit
Has anybody seen or used this yet?
http://www.flextek.com/
I found it on (cough) this site:
http://www.treehugger.com/files/2006...an_adapt_y.php
I did a search for ethanol conversion and this came up. Do these actually work?
I can't imagine how they would work...because certain fuel system components have to be made compatible with the ethonal, a drop in mysterybox ain't gonna fix the hardware that has to be ready for this kind of fuel...So I figure this is bogus crapolla...Stay away from these gadgets.
Possibly, but do you want to be the guinea pig? Hummer says the vehicle isn't designed for E85. That doesn't mean that the computer just isn't programmed for it or that it's only lacking the appropriate sensors. There are probably a whole host of other material compatibility issues as well. Fuel line and seal material just for starters. Wanna void a warranty?? Not me on this one. Besides, what nobody tells you is that because of the lower heat output of the alcohol vs gaoline, your fuel mileage will suffer too. We have enough worries with that as it is with gas being expensive these days. Not sure of the prices on E85 out there as I haven't seen it available here in FL, but I'd bet it isn't cheaper. So after all the money spent buying the necessary pieces and in most cases having to pay someone to install it, what will you get? Or more importantly will you even save anything? The jury is still out, but I'm not playing on this one. We can save some foreign oil, but I'd think long and hard before trying this. Of course it's just my opinion. But.....
Well, as I read deeper, I realized they aren't available for Throttle Body systems yet, only carbs, BUT they claim the R&D is going on for it right now. As you guys said, I doubt this would be easy, because the PCM would have to be programmed for a higher octane. According to what I found, E85 is 105 octane! That's pretty damn high.
Andreas_Sweden
Jul 14, 2013 01:04 AM
Mountain Trooper
Jul 17, 2008 07:40 PM
hummerjim
May 29, 2008 04:38 PM
geeggee
Feb 28, 2008 03:59 PM
jaycen29
Dec 28, 2006 05:37 AM
