Droopy H3
I have been reading up on H3 front end droop. My issue is only the driver's side droops. Everything looks solid under there and shock is not leaking. Was gonna crank the tbars but thought I might ask if someone had similar one sided droop.
not shocks
shocks have no effect on height,springs and t bars hold the truck up
EVERY single HUMMER (h3 anyhow) off the show room floor does this, but with different sides. They are ALL off center in one way or another. It's no big deal. Just crank the tbars until they are even ;)
Mine does that on the driver side, but I always attributed to the fact that my fat behind sits on that side... I had a friend crank the t-bar and that worked
It is known as the "GM lean" and has to do with factory set up, and spring settling after being strapped to rail cars for shipment. Other GM trucks suffer it as well. Been talked about all over many boards..... wake up and smell the print. :D
